XJ Quarter Glass Replacement
dagr8tim
Vehicle: 97 XJ
Post by dagr8tim » Sun Jun 13, 2010 9:51 pm
After my little incident in WV last weekend, I was in need of replacing a quarter glass on my 97 XJ. These instructions should work for any XJ, possibly ZJ's and any other gasket style window. After getting it done, Jay asked me to do a write up. XJ's are known for popping or shattering the quarter glass when flexing. For me, it was an upgrade to factory tinted quarter glass.
The first step is to obtain the new glass. If you are getting it from a junk yard, I suggest just cutting the gasket and popping the glass. I did use several flat screw drivers to work seal over the pinch weld on the body. If you take your time, this method works well. If you need to save the gasket/seal, this is the way to go. Just take your time and be careful not to rip the gasket/seal. You should be able to get the glass out without breaking it or destroying the seal.
Once you have your new glass, you have to get the glass out of your XJ. Most sources say to shatter the glass. This method is messy, but saves the gaskets/seals for reuse. My weapon of choice is a 2 inch ball and hitch that goes into my Class III receiver.
Once you have the glass shattered, you will need to remove the gasket/seal from the window opening and remove all the glass. I found a small phillips screw driver was great. You really need to pick the glass out of the corners.
Once the gasket is clean, I installed on the new glass. I started the installation by putting the lower rear corner in place on the pinch weld, and tilting it down until I could get the top rear corner lined up. At this point, you have to corners done and one of the 4 edges. I had a helper (a 9 year old) hold the glass with some slight pressure to hold it in place, while I used a small flat screw driver to work the gasket over the pinch weld. Once again take your time and be careful not to rip the gasket/seal. As you are lifting the gasket up to get it over the pinch weld, have your helper push on the glass in that same area. Work your way around. The last corner is a PITA, but just take your time.
Once you have the window fully installed. I pushed along the edges from the outside to ensure it was seated properly. Then I just loosened the trim around the window to make sure the gasket/seal was tucked behind the trim. It's really not that difficult and only took me about 2 hours to do both quarter glasses.
Before I did this, I did a ton of research and alot of methods say to use water based lube (KY Jelly) and a rope. I used this method for part of my installation, but it proved easier and quicker just to use a small screw driver. Basically with the rope, you wrap around the glass with the gasket/seal installed. From the inside you pull on one end while keeping the other end taught. This is supposed to pop the seal over the pinch weld. I wasn't super impressed with this method, because there were sections where it didn't work, and I'd have to use the screw driver to get the seal caught up to where the rope was hanging out.
Also, I don't have a picture of the gasket in profile, but it's basically an "H" where the glass sits in the top part and the pinch weld sits in the lower part.
Here's the glass & seal removed. As you can see it's pretty smooth.
Here's the glass installed.
Here's the carnage inside. I still need to clean up the broken glass.
1997 XJ Lightly Modified
1998 TJ Full on Mall Crawler
DubVThor
Vehicle: 2004 Jeep TJ
Re: XJ Quarter Glass Replacement
Post by DubVThor » Sun Jun 13, 2010 10:07 pm
dagr8tim wrote:...little incident in WV last weekend...
It's funny how once you cross the border, little things like putting the keys in your pocket slip your mind because you're having such a good time. :lol:
Looks good, glad to see you got it all fixed up.
2004 TJ 4.0L 5 speed, Winch, Lift, Tires, things and stuff.
dagr8tim
Vehicle: 97 XJ
Post by dagr8tim » Sun Jun 13, 2010 10:20 pm
After I got soaked in the monsoon. I went to see what I had in the Jeep to dry off on. I was so excited to have found an old baby blanket to dry off on, I forgot to put the keys in my pocket and just threw them on the passenger seat. Plus I had the tinted quarter glass sitting in the garage for the last year. So it was an excuse to finally get around to it and swapping it.
DubVThor
Post by DubVThor » Sun Jun 13, 2010 10:28 pm
Understandable... if there was one modern convenience I miss by owning a Jeep, it's definitely having to manually unlock it during a downpour as opposed to pressing the button and making a run for it.
Dest
Vehicle: 350Z
Post by Dest » Thu Jun 17, 2010 10:51 am
XJs have RKE :-P.
TrueBlueXJ
WVJC Graphics Designer
Vehicle: Jeepless
Post by TrueBlueXJ » Thu Jun 17, 2010 11:05 am
Dest wrote:XJs have RKE :-P.
Says you, Mr. Fancy Pants. :snooty:
Cannibal's Cave: http://cannibalwv.tumblr.com/ | The makings of a turd: viewtopic.php?f=51&t=24679
Jeepers-Creepers
Post by Jeepers-Creepers » Thu Jun 17, 2010 11:29 am
Tim you put that glass in the hard way. Most people run a peice of rope around the gasket then you set the bottom of the glass in and pull 1 side of your rope from inside all the way around. This flips the rubber over the pich weld as you pull the rope around. Atleast you got it in there though and the tint looks alot better.
04 Ford F-250, Ext. Cab, 6.8 V10 Tow Rig
85 Toyota Truggy Style, 60 Rear, Chromo'd 44 Front, Custom Back Half, Exo Caged, 4 link rear, Fox Air Shox, Warn 9.5, Twin Sticked, Dual Cases, Warn Premium Hubs, And who know's what else
dagr8tim
Vehicle: 97 XJ
Post by dagr8tim » Thu Jun 17, 2010 11:40 am
Todd, I tried the rope method and wasn't impressed. Maybe I used the wrong kind of rope.
Jeepers-Creepers
Post by Jeepers-Creepers » Thu Jun 17, 2010 12:07 pm
Thats the way we always did them at the body shop, I think even the glass companies do them that way. Once you figure it out it's really simple. Atleast you got it in there without breaking it though thats the main thing.
Cowboy80CJ5
Vehicle: Buggy in the making!
Post by Cowboy80CJ5 » Thu Jun 17, 2010 12:13 pm
You are right Todd. I have installed a few windshields with a rope, and it works VERY well. Did you put the rope in the right place? Either way, I REALLY would not suggest using a screwdriver to install glass. Ask me how I know..... :oops:
"Some people are like slinkies....they are good for nothing, but they still bring a smile to your face when you push them down a flight of stairs"
Not A Poser Custom Fabrication LLC
Sutton, WV 26601
304-701-7826
dagr8tim
Vehicle: 97 XJ
Post by dagr8tim » Thu Jun 17, 2010 5:20 pm
I wish the rope trick would have worked and maybe next time I'll use some nylon cord.
Forbes
Vehicle: Pair of Nike's.
Post by Forbes » Thu Jun 17, 2010 11:20 pm
Great write-up Tim. Thanks for sharing.
