What winch to use?
Steveakus
Vehicle: 01 Chevy 496 Tow Pig, Buggy
Re: What winch to use?
Post by Steveakus » Thu Jun 14, 2012 9:38 pm
so you think warns dont have chinese parts in them ??? your sadly mistaken if you answer yes
also 40 years ago TV's where better too, they where made in America then, er was it england :think: :bigthumb: :roll:
my winch has 5hp yours only has 4.2 ..... nanner nanner :dance:
sent from a non American made electronic device (man I wish we made those)
Certified GM Technician, Rough Country Dealer/Installer, All Around Good Guy
Buggy Build
Justin_WJ
Vehicle: 2000 WJ V8
Post by Justin_WJ » Thu Jun 14, 2012 10:07 pm
Now now children. Play nice. :)
armyjeep
Vehicle: 2014 JKU
Post by armyjeep » Thu Jun 14, 2012 10:11 pm
Unless you want to use it everyday, for a long time, buy any of them, they all work the same, a bumper weight. If you want one that is made to "BE USED" definetely spend the extra and buy the better winch "WARN". Also if you intend on using everyday, frequently you need to upgrade your alternator and battery.
Post by SLADE » Thu Jun 14, 2012 10:14 pm
Steveakus wrote:so you think warns dont have chinese parts in them ??? your sadly mistaken if you answer yes
You should refer back the first statement made. I don't care what brand you buy when you buy a CHEAP winch, you are getting just that, a CHEAP bottom shelf winch. It doesn't matter what name it's sold under.
Actually, my winch has a 6HP motor (12,500LB winch) and a Limited lifetime/3 year electrical warranty, is very waterproofed, and is made in China.
armyjeep
Vehicle: 2014 JKU
Post by armyjeep » Thu Jun 14, 2012 10:25 pm
that's a big winch, do you get to pull out a bunch of hummers?
tupton
Vehicle: 2006 Chevy Silverado
Post by tupton » Thu Jun 14, 2012 11:08 pm
I've had my mile marker 9000 for 4 years now and never had a problem. Pulls as slow as the seven year itch, but gets the job done.
xjpettit99
Vehicle: 99 jeep cherokee XJ
Post by xjpettit99 » Fri Jun 15, 2012 6:39 am
I'm using a smitty built xr8 and i like it but i keep considering getting an x2o winch
99' Jeep Cherokee XJ -4 1/2" lift, 33x12.5 Baja claws, Custom Bumpers front and rear, Hella 500 Fog lights, Smittybuilt XRC 8, roof rack, dana 44 rear, custom tube flares, lots of trimming
Cowboy80CJ5
Vehicle: Buggy in the making!
Post by Cowboy80CJ5 » Fri Jun 15, 2012 7:11 am
I have had 2 Mile Marker winches. The first one burnt up after 4-5 years. It was the same brand that Tom has right now. The second one has had problems as well, but is still working. For the money, I really cant complain about them to much. With that said, when I get another one, it WILL be a Warn. I do use mine fairly often both on myself, and on other people, but that is what happens when you get off of a dirt road every now and then. Guess that I am just not as good of a driver as the rest of you guys.
I have seen fairly good things out of the Smittybuilt winches, but they are the only "cheap" brands that I can speak of first hand. I agree that they are all pretty much the same regardless of brand name. The nice thing about the Smitty's is the lifetime warranty that you could get with them for a while through 4wd.com. I will probably be buying one of these when it comes time for one on my trailer.
"Some people are like slinkies....they are good for nothing, but they still bring a smile to your face when you push them down a flight of stairs"
Not A Poser Custom Fabrication LLC
Sutton, WV 26601
304-701-7826
Justin_WJ
Vehicle: 2000 WJ V8
Post by Justin_WJ » Fri Jun 15, 2012 9:07 am
^ I'll definatly be buying a winch with a lifetime warranty and is waterproof
Post by SLADE » Fri Jun 15, 2012 6:55 pm
redjeep wrote:that's a big winch, do you get to pull out a bunch of hummers?
The 12.5 was only about $100 more than the 9.5. Just figured I'd get the most for the money.
Post by EricsGreen98Tj » Sat Jun 16, 2012 10:15 pm
redjeep wrote:Also if you intend on using everyday, frequently you need to upgrade your alternator and battery.
TOO TRUE! I was pulling myself up a rock and my dang headlights kept dimming. I have a good battery but I guess Im going to have to upgrade my alt.
Anyone know if I need the Zj alt with the 6 grooves or the 7 groove one. Its dark outside..
jeepers
Post by jeepers » Thu Jul 19, 2012 8:41 pm
I'll say spend the extra money, buy a WARN and go on with life.
Look at it this way, When youre stuck out in the middle of BFE by yourself with nobody around but you and the mud hole/creek youre stuck in...
which would you rely on? A cheap winch that you saved a few dollars on OR a well built winch?
96 XJ long arms, lockers and 35's--RIP
93 S-10 LSX powered (under construction)
98 2500 tow rig
The white thing on the left
Post by J-rod » Sun Aug 19, 2012 1:54 pm
looking at winches again as mine is sold.
found a decent 8500 winch in my price range, but noticed it comes with a haws instead of roller fair lead with steel cable. seems odd. should i be concerned?
Post by J-rod » Mon Aug 20, 2012 10:23 am
going to get a new one. most likely order tonight.
Smitty XRC8 or the Superwinch 8500?
Justin_WJ
Vehicle: 2000 WJ V8
Post by Justin_WJ » Tue Aug 21, 2012 8:49 pm
I'm gettin the xrc 8 as well. Good reviews, great looking, and ya can't beat the price. I don't need a winch that's gonna last longer than my jeep...
