How to use a Dana 300 T-case in your XJ-TJ
LS1Jeeper
Post by LS1Jeeper » Sat Feb 02, 2008 10:20 pm
mxoring
Re: How to use a Dana 300 T-case in your XJ-TJ
Post by mxoring » Sat Mar 01, 2008 8:19 pm
Have you found one yet??
LS1Jeeper
Post by LS1Jeeper » Sat Mar 01, 2008 10:24 pm
Yeah about 175-225 going rate for a decent looking one. Now all I need to find is the money to buy it.
jeepers
Post by jeepers » Sun Mar 02, 2008 8:04 pm
are you going to twin stick it?
96 XJ long arms, lockers and 35's--RIP
93 S-10 LSX powered (under construction)
98 2500 tow rig
The white thing on the left
LS1Jeeper
Post by LS1Jeeper » Sun Mar 02, 2008 10:59 pm
Yeah .. look at this, I suppose it will look somthing like that
http://www.pirate4x4.com/forum/showthread.php?t=311519
junkyarddog
Post by junkyarddog » Wed Mar 05, 2008 1:04 pm
only sad thing is is after you buy the for around 200.00 then the flip kit for 500.00 and change...the 4 to 1 for 500 and some change and a 100.00 clocking ring you can pick yourself up an Atlas for pennies more.
2000 XJ.....lets see what happens
jeepers
Post by jeepers » Tue Mar 11, 2008 6:53 pm
or, run 7:13 gears instead of the 4:1 low, leave it pass drop and get a clocking ring..call it done.
98 2500 tow rig
LS1Jeeper
Post by LS1Jeeper » Tue Mar 11, 2008 9:19 pm
Nah I'm going no flip kit and 7.17 gears but I'll buy a clocking ring
1_TON_YJ
Post by 1_TON_YJ » Thu Apr 24, 2008 9:43 pm
I would rethink 7.17 gears if your running a 60 rear.....
95' Wrangler 35 spline 60's atlas 42s
01' XJ HP44/FF60 6speed manual 5.13s 35 LTBs
98' Wrangler Sahara Reincarnation DD/weekend warrior
06' Quad Cab Cummins Edge juice with attitude, K&N Intake, Muffler delete = Toy hauler
http://www.americanfourwheeler.com
LS1Jeeper
Post by LS1Jeeper » Thu Apr 24, 2008 11:52 pm
Thats when it was going to have the stock 4.0 with no horsepower
now with the LSX motor it's getting either 5.86 or 6.17
Top Speed (wheel speed) is 103 for 6.17 and 112 for 5.86
Thats with the rev limiter at 6k it sound spin 6600 easy but theres no point I'd rather it live longer than get an extra 600 rpm out of it
I'm not getting 4.1 kit either it should be fine with the rear gear thats going it. It's not like I'm going to drive more than a mile or two on paved roads at best
jeepers
Post by jeepers » Sat Apr 26, 2008 10:40 am
I would, if you need it, its there.
98 2500 tow rig
LS1Jeeper
Post by LS1Jeeper » Sat Apr 26, 2008 8:18 pm
Thats $650 I can spend on somthing else .. if it won't go... it just needs more skinny pedal
1_TON_YJ
Post by 1_TON_YJ » Tue Apr 29, 2008 10:05 pm
I said that only because of the pinion size. They get really small anything above a 5.86. Our 5.38s are about perfect IMO.
LS1Jeeper
Post by LS1Jeeper » Tue Apr 29, 2008 11:09 pm
I know they get weaker the lower the gear ... I'm trying to keep it geared low enough I don't have to crawl up stuff at 20 mph..
4runner
Post by 4runner » Sat Jun 06, 2009 12:08 pm
i got some d300's if you guys get the itch....
