STAK or ATLAS?
Re: STAK or ATLAS?
I have plenty of room for a STAK 3 speed, But I may run into issues with the Atlas 4 speed. The Stak is 13" long and the Atlas is 17" long. 4" is alot when working with a Jeep. The STAK is more suitable to me for it's size. will be doing a flat belly at the same time, sothe rear output will be slighlyt higher than it is now.
2014 Wrangler Unlimited
2013 Wrangler
2004 Wrangler
2001 Dodge Ram 2500
2013 Wrangler
2004 Wrangler
2001 Dodge Ram 2500
Re: STAK or ATLAS?
LENGTH COMPARISON FOR
DIFFERENT TRANSFER CASES
Model / Length
STaK 4X4 3 Speed 13.0"
Atlas 4 speed 17"
Atlas II 5.08 13.8"
NP 203 21.5"
NP 205 13.0"
Dana 300 11.5"
Jeep Dana 20 10.5"
NP231 20+"
241OR 15"
Model / Length
Atlas 4 speed 17"
Atlas II 5.08 13.8"
NP 203 21.5"
NP 205 13.0"
Dana 300 11.5"
Jeep Dana 20 10.5"
NP231 20+"
241OR 15"
2013 Wrangler
2004 Wrangler
2001 Dodge Ram 2500
2013 Wrangler
2004 Wrangler
2001 Dodge Ram 2500
Re: STAK or ATLAS?
to be honest id take either one since i cant afford one .........they have been on the wish list for awhile
- Cowboy80CJ5
- Bullet Proof
- Vehicle: Buggy in the making!
Re: STAK or ATLAS?
SLADE wrote:How so?tupton wrote:Atlas
'nuff said
I do not see where Atlas has Stak to the point you can make a "nuff said" argument.
Considering price, size and gearing options, I do not see where Atlas is a better choice than a Stak. The Atlas 4 speeds really only have 3 usable gears. atleast 1 gear is worthless and really not even worth having.
Sounds to me like you already have the answer that you are looking for brotherSLADE wrote:I have plenty of room for a STAK 3 speed, But I may run into issues with the Atlas 4 speed. The Stak is 13" long and the Atlas is 17" long. 4" is alot when working with a Jeep. The STAK is more suitable to me for it's size. will be doing a flat belly at the same time, sothe rear output will be slighlyt higher than it is now.
"Some people are like slinkies....they are good for nothing, but they still bring a smile to your face when you push them down a flight of stairs"
Not A Poser Custom Fabrication LLC
Sutton, WV 26601
304-701-7826
Sutton, WV 26601
304-701-7826
Re: STAK or ATLAS?
I am leaning toward STAK, but honestly impartial. The STAK's specs are better for me and I prefer them over ATLAS for that reason. The reputation of ATLAS makes me have second thoughts about the STAK though. In a perfect world, The STAK 3 speed would have the ATLAS reputation and track record. My only problem with the ATLAS is the size.
If I would change my mind on a 3 or 4 speed and settle for a 2, I'd probly go with ATLAS.
Niether one seems to be a perfect answer, and there are sacrifices either way.
Thats why I would like to hear reasons instead of "nuff said"...
2013 Wrangler
2004 Wrangler
2001 Dodge Ram 2500
2013 Wrangler
2004 Wrangler
2001 Dodge Ram 2500
Re: STAK or ATLAS?
i think i heard recently that the 4 speed atlas is on back order for like 3 months, but i read that like 2 months ago.
Re: STAK or ATLAS?
Low demand high dollar stuff is often behind 'cause it's just too expensive to make many at one time just to sit on a shelf.
'02 KJ 3.7 V6 45RFE
Frankenlift-3" or so
245/75-16 MT/R
Skids
RRO rockrails
Cook Bros. diff guard
Powertrax No-Slip and no sway bar-not exactly a backroad bullet
10LB. Powertank system
245/75-16 MT/R
Skids
RRO rockrails
Re: STAK or ATLAS?
I expect a wait for either one.
2013 Wrangler
2004 Wrangler
2001 Dodge Ram 2500
2013 Wrangler
2004 Wrangler
2001 Dodge Ram 2500
- Post Whore
- Vehicle: 2015 Challenger Scat Pack
Re: STAK or ATLAS?
X2LS1Jeeper wrote:Stak .. but don't get in a hurry for it
Standing 112 miles from the best wheeling in WV.
- Jeepers-Creepers
- Post Whore
- Contact:
Re: STAK or ATLAS?
Just build a 300 with a Tera Low and twin stick it you already have one. What is the reason for wanting the Atlas or Stak. I mean I don't know alot about T-cases but unless your really planning on building the TJ what is the need that a Tera Low and a front and rear lock can't do for alot less money. I mean maybe thats a stupid question from me but I'm just curious.
04 Ford F-250, Ext. Cab, 6.8 V10 Tow Rig
85 Toyota Truggy Style, 60 Rear, Chromo'd 44 Front, Custom Back Half, Exo Caged, 4 link rear, Fox Air Shox, Warn 9.5, Twin Sticked, Dual Cases, Warn Premium Hubs, And who know's what else
Re: STAK or ATLAS?
there are no stupid questions... the multiple ranges built into the stak or atlas are invaluable...
they allow you to run a more streetable axle ratio, while still having different choices while off road.
En este mundo hay dos tipos
Los de armas cargadas y los que cavan
- Jeepers-Creepers
- Post Whore
- Contact:
Re: STAK or ATLAS?
So instead of having a lets use the Dana 300 with a Tera Low you have a stock high range and a new Super Low. Where with the Atlas or Stak you would have a 2 wheel drive 1,2,3,or 4 speed in 2 wheel drive or 4x4. So he can actually drive the T-case in 3rd 2wd on the main road instead of changing rearend gears and using the T-case output as the gear change.
- TJinWV
- Lifetime Member
- Vehicle: 2006 TJ
- Contact:
Re: STAK or ATLAS?
Jeepers-Creepers, that confused me.
The 3-speed stak is essentially like having 4-hi, 4-low, and 4-superlow. It's like having a 203-205 doubler - you get 1:1, 2:1, and 4:1 ratios, all in one convenient package. The 4-speed Atlas gives you yet another option. Like having a Klune underdrive connected to your 231.
Dan - TJinWV <><
2002 TJ, 2" OME lift, ARBs
.ɹǝʌo ǝɯ 11oɹ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
Re: STAK or ATLAS?
I considered building the 300 (1ton has my 300 now though), thats what got me looking at the STAK 300 (which is atill being considered). after some thought, Ive started considering the 3 speed and 4 speed. gear options are allways a good thing. 2 low ranges are really needed for trails.
2013 Wrangler
2004 Wrangler
2001 Dodge Ram 2500
2013 Wrangler
2004 Wrangler
2001 Dodge Ram 2500
- Jeepers-Creepers
- Post Whore
- Contact:
Re: STAK or ATLAS?
Yeah it was a little confusing for me too lol. So then this doesn't help any on the road just on the trail? Seems like alot of money for 1 or 2 extra gears. but I guess even a Tera low isn't cheap. There is alot of times though that the Tera would be to low and would be nice o have a normal low range. Well Slade you know what my opinion is sorry to get off topic I was just wondering.TJinWV wrote:Jeepers-Creepers, that confused me.
