Possessed grand cherokee. help...
- Beth
- Web Wheeler
- Vehicle: 2011 JK
A friend of mine has a 2003 Jeep Grand Cherokee. A few months ago while she was driving her radio went off and her dash lights started flashing. It continued to happen on and off so she took it to have it looked at. She just got it back from the shop and they told her that the alternator was fine and she just had a loose battery terminal. While I was on the phone with her just now she said that all of her lights started flickering on the dash and all of her gauges(including speedometer) dropped to zero, but it is running fine. All of her lights came on.. check engine, abs, etc. The lights for the temp. directions are fine it is just the dash having issues. Any ideas????
The less you know the more you THINK you know!
prchrman wrote: hells is frozen over with snow, and prchrman is leading the way through
- Rookie
Re: Possessed grand cherokee. help...
maybe the connection where the gauge cluster plugs in is loose?
Ignition related? Loose ground?
2014 Wrangler Unlimited
2013 Wrangler
2004 Wrangler
2001 Dodge Ram 2500
2013 Wrangler
2004 Wrangler
2001 Dodge Ram 2500
- BacklashXJ
- Curb Crawler
- Contact:
it's def. posessed. take it to a holy man RIGHT NOW.
beat it with a cross, flood the engine with holy water. that should solve the problem.
2000 Jeep Cherokee Patriot Blue/Rustolium Black
custom 4-link front and rear, 16" travel coilovers, PSC full hydro, 38's, 5.13's locked and loaded D60/14BFF, D300. WIP.
2001 Mitsubishi Eclipse Patriot Red
5spd, bolt-ons and some upgrades. DD.
maybe a fuse too....i'm guessing they would have checked that though. I had a civic that did that and what had happened is a fuse was losing connection.
- Beth
- Web Wheeler
- Vehicle: 2011 JK
BacklashXJ wrote:it's def. posessed. take it to a holy man RIGHT NOW.
Gee thanks for all the help buddy.. I know exactly who to call when I am having Jeep troubles
Any codes?Body control module would be my guess.
'02 KJ 3.7 V6 45RFE
Frankenlift-3" or so
245/75-16 MT/R
Skids
RRO rockrails
Cook Bros. diff guard
Powertrax No-Slip and no sway bar-not exactly a backroad bullet
10LB. Powertank system
245/75-16 MT/R
Skids
RRO rockrails
- Beth
- Web Wheeler
- Vehicle: 2011 JK
No codesXRKJ wrote:Any codes?Body control module would be my guess.
probably the cluster itself I've seen alot of problems with them, and replaced quite a few of them. But I would start by checking the the big connectors at the left and right kick panles(2 on each side), seen some issus there to.
96 XJ 5.5"RE lift, 33x12.5"Trxus mts on soft 8s, Proto fab fr bumper, MM9500se winch, olympic offroad roof rack, RE hack-n-tap and shaft, rear ARB air locker, ZJ rear disc brakes, and a few other mods.
- MidwayJeremy
- Curb Crawler
BAPTIZE IT IN A RIVER!!! IT WILL KILL ALL ELECTRICAL DEMONS!!
2000 WJ LIMITED V8 2in BBS, 265/75/16, K&N INTAKE, KOLAK EXHAUST, IRON ROCK SLIDERS, JKS DISCO's, D44a AUSSIE LOCKER ..DAILY DRIVER.
992 JEEP XJ, 4.0L, NP231 sye, 4.56, 8.8 Lockright D30 Aussie 9" Lift RockKrawler LA's and 38s TSLs
- Beth
- Web Wheeler
- Vehicle: 2011 JK
Maybe I will tell her to try Mykals approach and bury it in the biggest mud hole she can find!!!!
- Post Whore
- Vehicle: 2015 Challenger Scat Pack
you should PM Prchrman, maybe he could do an exorcism & cure it right up...
Standing 112 miles from the best wheeling in WV.
- BacklashXJ
- Curb Crawler
- Contact:
bethsxj wrote:Gee thanks for all the help buddy.. I know exactly who to call when I am having Jeep troubles
