Rear diff. leaking
Nubster
Rear diff. leaking
Post by Nubster » Sat Feb 21, 2009 3:13 pm
The rear diff is leaking on my "new" Jeep. Do I just pop the rear cover, drain, clean, seal back up with RTV, and refill with fluid? Just want to make sure so I don't screw it up. And yeah, something this simple I could screw up...lol
And what should I refill with and how much? It is a D35 if that matters.
Vec
Vehicle: 01 TJ
Re: Rear diff. leaking
Post by Vec » Sat Feb 21, 2009 3:16 pm
yes, do that and fill it till it runs out the plug.
Nubster
Post by Nubster » Sat Feb 21, 2009 3:26 pm
Cool. Thanks for the fast response. Just standard diff. fluid or is there something else that might be better recommended?
1_TON_YJ
Post by 1_TON_YJ » Sat Feb 21, 2009 3:40 pm
Just your standard gear oil will be good.
95' Wrangler 35 spline 60's atlas 42s
01' XJ HP44/FF60 6speed manual 5.13s 35 LTBs
98' Wrangler Sahara Reincarnation DD/weekend warrior
06' Quad Cab Cummins Edge juice with attitude, K&N Intake, Muffler delete = Toy hauler
http://www.americanfourwheeler.com
yotamike
Vehicle: 94xj 92 1500
Post by yotamike » Sat Feb 21, 2009 4:21 pm
I like the gray rtv the best
i hope this doesn't get deleted
Nubster
Post by Nubster » Sat Feb 21, 2009 6:37 pm
I already got and used the red. Everything went pretty smooth especially for me. Now just gotta see if it holds up.
tupton
Vehicle: 2006 Chevy Silverado
Post by tupton » Sat Feb 21, 2009 7:19 pm
I've always used red also, but any color will work for a differential, blue, black, etc.
Tom Upton
MasterShakeXJ
Post by MasterShakeXJ » Tue Feb 24, 2009 12:19 am
-take all the bolts out except the top most bolt, just loosen it.
-give the cover a couple whacks with a rubber mallet to free it, let it drain completely.
-scrape all the old RTV off, i used a razor blade. one of those scrapers they use for inspection stickers would also work well.
-check everything to make sure it looks good.
-you can use some kinda brake parts cleaner on the cover to clean it up.
-then put the new RTV on and match it up, hand tighten the bolts and let it set. i let it set for about an hour, then filled it and tightened the bolts down.
i think that's it, pretty straight forward. i wasn't too sure about it when i did mine, but it was pretty easy.
TrueBlueXJ wrote: I was squealing like an Asian schoolgirl at a Jonas Brothers concert
IEATRKS84
Post by IEATRKS84 » Tue Feb 24, 2009 12:40 am
Nubster wrote:The rear diff is leaking on my "new" Jeep. Do I just pop the rear cover, drain, clean, seal back up with RTV, and refill with fluid? Just want to make sure so I don't screw it up. And yeah, something this simple I could screw up...lol
Sell the jeep............ :bigthumb:
Nubster
Post by Nubster » Tue Feb 24, 2009 12:58 am
lol...yeah...that is how I used to do it. I got it all sealed up and looking good. Now fluid is leaking out of the plug hole >:(
Anyone interested in a 1996 DD Jeep Cherokee? I'll make you a great deal.
tupton
Post by tupton » Tue Feb 24, 2009 8:03 am
I used to have gear oil leak out of the crappy rubber plug after I changed my fluid too. After a few days the level will drop slightly and you'll be ok.
Tom Upton
TrueBlueXJ
WVJC Graphics Designer
Vehicle: Jeepless
Post by TrueBlueXJ » Tue Feb 24, 2009 8:27 am
I RTV the rubber fill plug before I put it back in. Hasn't leaked out around the plug since.
Cannibal's Cave: http://cannibalwv.tumblr.com/ | The makings of a turd: viewtopic.php?f=51&t=24679
tupton
Post by tupton » Tue Feb 24, 2009 9:55 am
Good idea Kyle! I never thought about doing that.
Tom Upton
XRKJ
Post by XRKJ » Tue Feb 24, 2009 1:42 pm
Yeah that's what I do with my 8.25.Doesn't leak anymore.
'02 KJ 3.7 V6 45RFE
Frankenlift-3" or so
245/75-16 MT/R
Skids
RRO rockrails
Cook Bros. diff guard
Powertrax No-Slip and no sway bar-not exactly a backroad bullet
10LB. Powertank system
