NEED INJECTORS??
NEED INJECTORS??
i have heard of putting ford bosch 4 hole injectors in the jeep 4.0, but still not sure what pound to get, 19 or 24. anyone have any ideas, or done this before. thanks
- Bullet Proof
Re: NEED INJECTORS??
19 pound injectors are gonna starve a stock 4.0L .
So I'd say it would have tobe the 24s if that is the choice.
What exactly is this supposed to do?
Real men don't wear Bowties
99 TJ Sahara 4.0 5-Sp Trail Rider
06 LJ 4.0L six speed My DD
90 XJ Project F-XJ (Ford-eXtreme-Jeep!!)
94 F700 U-RV RV+Tow rig 5.9Lcummins /6 sp
77 F150 351M4x4 not stock 4-Sp (farm/Tow Mule)
new or used? what kinda shape?yotamike wrote:i have 6 24# ones i sale for 40.00
- dagr8tim
- Web Wheeler
- Vehicle: 97 XJ
- Contact:
Jim, the Jeep injectors have 1 big hole. The Ford injectors have 4 smaller holes. The theory is that the fuel is a finer mist with the ford injectors and thus you get a better atomization of the fuel/air mixture.
1997 XJ Lightly Modified
1998 TJ Full on Mall Crawler
the ford bosch is supposed to be the same inj. only it has 4 discharge holes, versus stock jeep only having just one. so the ford 4 hole will atomize the fuel better upon discharged.nitecop wrote:19 pound injectors are gonna starve a stock 4.0L .
- smccollamjr
- WVJC Member
- Vehicle: '00 TJ
If you've got a Renix 4.0 use 19lb, if it's an HO use 24lb.
gotcha, thanks man. is there a certain place to get these at?smccollamjr wrote:If you've got a Renix 4.0 use 19lb, if it's an HO use 24lb.
- smccollamjr
- WVJC Member
- Vehicle: '00 TJ
I got mine from this guy:
http://www.precisionautoinjectors.com/
but they are usually cheaper from his ebay store:
http://stores.shop.ebay.com/Precision-A ... QQ_armrsZ1
thanks man. not to offend, but i would rather just get brand new ones to put in, but thanks for the help.smccollamjr wrote:I got mine from this guy:
- smccollamjr
- WVJC Member
- Vehicle: '00 TJ
No problem. FWIW, my rebuilt ones have been working great.
I've been using RC Engineering stuff for years.Sometimes all you need is a good clean and balance,especially if the engine's stock inside.There is a calculator on the site to help with injector sizing.
http://www.rceng.com
'02 KJ 3.7 V6 45RFE
Frankenlift-3" or so
245/75-16 MT/R
Skids
RRO rockrails
Cook Bros. diff guard
Powertrax No-Slip and no sway bar-not exactly a backroad bullet
10LB. Powertank system
245/75-16 MT/R
Skids
RRO rockrails
just got the injectors today. and helful tips before i tear into them tomm.
thanks
thanks
- dagr8tim
- Web Wheeler
- Vehicle: 97 XJ
- Contact:
Do they have new o rings? If not, it's very cheap insurance. Also, IIRC, you should soak them in oil to soften them up alittle.19558077 wrote:just got the injectors today. and helful tips before i tear into them tomm.
thanks
