Track Bar Bracket Issues
TJinWV
Vehicle: 2006 TJ
Post by TJinWV » Sat Apr 18, 2015 8:24 pm
So I tracked my death wobble issue down to the axle-side front track bar bracket. Right when I saw it, I realized what was going on. In the past, I had an aftermarket track bar with a larger-than-stock bolt through that bracket, so I had drilled it out for the new bolt to fit. I picked up a new JKS adjustable track bar, and after fighting to get the old one out (I had to cut the bolt twice with a sawzall, because it was seized to the bushing sleave), I just slapped the new one in and forgot about it. Now I realize that the JKS bar had a stock-size bolt in it, so there is movement all around the bolt.
So my question is - should I attempt to ream out the JKS bushing, or should I attempt to fix/replace the axle-side track bar bracket? The bracket does have some scoring from the previous sawzall work, though I don't think it's enough to compromise it's integrity. I have no welder or welding experience, and I don't think a major suspension component is a good place for me to start. :naughty: I'm open to suggestions for replacement or correction options.
Dan - TJinWV <><
2002 TJ, 2" OME lift, ARBs
.ɹǝʌo ǝɯ 11oɹ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
ledzep_06
Re: Track Bar Bracket Issues
Post by ledzep_06 » Sat Apr 18, 2015 8:54 pm
Have someone weld a washer on the front and back side of the trackbar bracket thats the same I.D. as the bolts O.D. just a thought
Post by J-rod » Sat Apr 18, 2015 9:28 pm
Imo get a replacement bracket and get someone to weld it up for you. I bet Charlie Ho would help.
notajeep
Vehicle: 1993 Explorer
Post by notajeep » Fri Sep 18, 2015 10:47 pm
BTT
So what did you guys do with the track bar bushing? I know you told me but I can't remember. Trying to chase down the death wobble and everything seems tight as far as steering and suspension go. Only thing I can think of is the vehicle is severely out of alignment and the BFGs are el garbago.
MARV
Vehicle: 05 LJ Wrangler
Post by MARV » Fri Sep 18, 2015 11:14 pm
BFG caused mine.
05 LJ
14 JKU
15 DART
Do you even wheel Bro?
cherokeebill
Vehicle: 91 xj
Post by cherokeebill » Sat Sep 19, 2015 3:08 am
I could weld a couple washers in place
3 inch lift,35s and fenders chopped...Made by me
TJinWV
Vehicle: 2006 TJ
Post by TJinWV » Sat Sep 19, 2015 8:16 am
notajeep wrote:BTT
We pressed out the bushing with the stock bolt hole and pressed in one of JKS's HD bushings and used the larger bolt. So the bolt matches the hole in the bracket. It should not be a problem now. I bet the new shoes will help tremendously, if not eliminate the problem.
Dan - TJinWV <><
notajeep
Post by notajeep » Sat Sep 19, 2015 11:48 am
Yeah I'm hoping it's a tire and alignment issue.
cherokeebill
Vehicle: 91 xj
Post by cherokeebill » Sat Sep 19, 2015 2:57 pm
Too much toe in causes death wobble....had this happen to me a couple times
