Selectable locker in JK Dana 30
jawest12
Vehicle: 2018 JL
Post by jawest12 » Wed Feb 10, 2016 9:10 pm
Discuss.....
holliewood61
Vehicle: 81 cj7 99 tj 60 cj5 08 wk 00wj
Re: Selectable locker in JK Dana 30
Post by holliewood61 » Wed Feb 10, 2016 11:38 pm
My thought is why dump that kind of coin into a d30? I feel like if you're going to do more than a lunchbox locker in a 30 you should just go ahead and start hunting a 44.
Beat it to fit. Paint it to match.
08 wk stock
00 wj daily driver
99 tj mostly stock 31's
81 cj-7 304, efi, th400 dana 20, dana 44's, 4.88's, locked, some bumpers, some armor, on 37's
60 cj-5 a work in progress
MARV
Vehicle: 05 LJ Wrangler
Post by MARV » Thu Feb 11, 2016 12:12 am
I run a lunchbox in my 30. I daily drive it in the winter as well. If you drive like you have some sense you will be fine. I wouldn't suggest cruising down the highway in 4H, but if you're going that fast did you really need 4WD? J-rod runs an ARB in his 30 maybe he will chime in on this.
05 LJ
14 JKU
15 DART
Do you even wheel Bro?
Post by J-rod » Thu Feb 11, 2016 12:16 am
Marv is correct. I run an ARB in mine. It is sleeved and gussets and Poly BJ too. I have had very good luck with mine.
Post by smccollamjr » Thu Feb 11, 2016 12:17 am
I agree with Marv. My TJ isn't s daily driver but it still sees more pavement than dirt. I haven't had any issues with my Aussie in the front, you just have to drive with some sense.
Post by J-rod » Thu Feb 11, 2016 12:26 am
My axles should be for sale relatively soon depending on how soon you're wanting to upgrade
ZiGGY
Vehicle: 2014 WK2, 2008 JK
Post by ZiGGY » Thu Feb 11, 2016 11:08 am
Had a Aussie in the front of my XJ and loved it. No problems but you do get "whats that clinking sound".....
14 Jeep WK2 Limited
08 Jeep JK 4D Rubicon - 6.5in lift, 35x12.50 Cooper Discovery SST, Smitty Built Winch, Solid diff covers, Warn rear bumper
jawest12
Vehicle: 2018 JL
Post by jawest12 » Thu Feb 11, 2016 11:28 am
From Zack's research, can't do a lunchbox or auto locker in a 2012+ JK, puts it in limp mode. And i'm too cheap for full axle replacement.
I may just suck it up, and wait until a few days down the road.
Post by EricsGreen98Tj » Thu Feb 11, 2016 4:36 pm
In my Tj I run an Eaton E Locker and really like it. Perfect for a DD IMO.
Post by smccollamjr » Thu Feb 11, 2016 4:45 pm
EricsGreen98Tj wrote:In my Tj I run an Eaton E Locker and really like it. Perfect for a DD IMO.
That's what I really want in my rear axle.
ledzep_06
Post by ledzep_06 » Thu Feb 11, 2016 4:47 pm
You cant do an auto locker in the REAR of a 12+ JK, at least not until the factory transmission software is cracked. The front you can lunch box away. If your going selectable id suggest an OX. no air lines to leak, no internal o rings to leak, no drilling into your housing, no need to buy an on board compressor, you can manually engage/disengage it in an emergency, and you get a beefy buttocks cover with it.
wharthog69
Vehicle: 2008 JK
Post by wharthog69 » Thu Feb 11, 2016 4:55 pm
Second the OX
If I hadn't wound up with the Prorock, that's the way I would have gone.
jawest12
Vehicle: 2018 JL
Post by jawest12 » Thu Feb 11, 2016 8:39 pm
Ahhh, my mistake. I was thinking that was for the front as well, lol.
rdcox23
Vehicle: 2005 Wrangler LJ
Post by rdcox23 » Fri Feb 12, 2016 4:51 pm
Ever considered a Detroit Tru Trac in your Dana 30?
I know it's not a "real" locker, but it provides a lot of traction. It is also mechanically driven so there are no clutches that can wear out.
Just a thought..........
LIVING IS:
Living is a thing you do
now or never.............which do you?
Post by EricsGreen98Tj » Fri Feb 12, 2016 7:56 pm
I really wish that someone would make a true locker, that reverts to a LSD when not locked. When I had my TruTrac in the rear my Tj was unstoppable in the snowy weather. Was defiantly way smoother than running with the rear ARB locked..
