UPDATE::: Wobble.... Wobble.....
- Forbes
- Post Whore
- Vehicle: Pair of Nike's.
I've been having a little problem with the Jeep lately, and I'm looking for a place to start in tracking it down.
A few weeks ago, I noticed that when braking, I would get a bit of a wobble in the steering wheel. Now that I have added 3" of more spring to my Jeep, I feel it a lot more (more sensitive, I guess). Also, sometimes if I brake REALLY hard, the jeep will want to pull to the right (passenger side). Other times, I can brake, and feel nothing, it stops on a straight path, as it should. In the last few days, I have noticed that if I feel the "wobble" when I brake, I sometimes feel it again as I start to accelerate. It's there for a minute, then goes away.
I've heard a few of you talk about calipers sticking... is this my problem? I looked at the front brakes this past weekend, and they looked okay, and I have plenty of pad left. Rotors didn't seem to be in bad shape either. All I could think of is a sticking caliper, or a warped rotor....
Anyone ever have this happen, or have any suggestions for where I should start looking/replacing? If it is a caliper, are they expensive to replace?
- TJinWV
- Lifetime Member
- Vehicle: 2006 TJ
Re: Wobble.... Wobble.....
Sounds like a warped rotor. It's typically not something you can really see by looking at the rotor.
Dan - TJinWV <><
2002 TJ, 2" OME lift, ARBs
.ɹǝʌo ǝɯ 11oɹ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
- MasterShakeXJ
- Curb Crawler
rotors arent too bad to replace, just depends what kind you get. are your end links on your swaybar at the same height on both sides? sometimes if ones higher than the other it can cause your jeep to pull one direction or the other when braking. maybe another thing to check would be ujoints, not sure if that would be the problem though.
TrueBlueXJ wrote: I was squealing like an Asian schoolgirl at a Jonas Brothers concert
Good time to change out pads and rotors.
Check your caliper on the driverside. it may be stuck and not clamping all the way, or not as hard. If only 1 front brake is working, it will pull to the side that is working.
- Forbes
- Post Whore
Good thought, but I haven't had my swaybar connected since April, so I don't think that's it.MasterShakeXJ wrote: are your end links on your swaybar at the same height on both sides? sometimes if ones higher than the other it can cause your jeep to pull one direction or the other when braking.
Kind of what I thought I might have to do... They sell a "caliper grease", don't they? If one is stuck, should I try that, or is it more like once they start to stick, they're better off being replaced?SLADE wrote:Good time to change out pads and rotors.
Had a similar problem mine was the tires were out of balance and would only show when I braked hard
Just something else to try
03 Red TJ 6" Fabtech LA, 35 MTR's, Ramsey winch, A to Z rockers, JFL Front and Rear Bumpers 4.88 gears with Auburn e-locks coming soon
pull the wheels and make sure you don't have mud in them
prchrman wrote:pull the wheels and make sure you don't have mud in them
MUD...
The most overlooked problem (or cause of)
- Forbes
- Post Whore
I just had all four wheels off on Sunday and everything was clean. The problem has been going on since before then, so I ruled mud out. I have had it through my balance off before though.SLADE wrote:prchrman wrote:pull the wheels and make sure you don't have mud in them
MUD...
- Jeepers-Creepers
- Post Whore
I would say you warped a rotor it don't take much to get one hot or even driving through a nice cold mud hole. Have them turned at a parts place or brake shop much cheaper than buying new ones and replace the pads when you do it.
04 Ford F-250, Ext. Cab, 6.8 V10 Tow Rig
85 Toyota Truggy Style, 60 Rear, Chromo'd 44 Front, Custom Back Half, Exo Caged, 4 link rear, Fox Air Shox, Warn 9.5, Twin Sticked, Dual Cases, Warn Premium Hubs, And who know's what else
- 94YJprestonWV
- Rookie
if you have to replace the caliper i think they are pretty cheap, when i went on that last trail ride lilredxj replaced his and it was like 20 bucks
94 YJ 4" Rough Country lift with 31 10.50 15 Cooper Discoverer STT tires, herculined, JKS quick disco's, A to Z rocksliders, 10,000lb Smittybilt Winch, Gen Right full body corner armor, Aussie lockers front and back
- Forbes
- Post Whore
yea, I was just looking at parts... Calipers around 20-25... rotors, not a whole lot more... not bad at all. Just more work. lol.
check your wheel bearings?
- Forbes
- Post Whore
No, haven't done that...prchrman wrote:check your wheel bearings?
jack it up, put hands on tire at 12 and 6 and try to wobble it...if it does you have a bearing to replace, if it does not then it may be the rotor...usually a bit of noise when the bearings get bad enough, but worth checking
