Back in the game - LJ style
A place to keep all those build threads.
Jeep Ride
Vehicle: 98 JeeP xj
Re: Back in the game - LJ style
Post by Jeep Ride » Tue Apr 03, 2018 7:54 pm
Good looking Jeep
Ridin High Livin Low
Key Board Crawler
98 xj 4.0L/231/8.25/ AW4 / 3 inches an 31 x 10,50 A/T 's
jcr stage 1 sliders frt/rear hitches warn t.case skid ruff stuff 8.25 diff cover/ rough country dana 30 skid
four in floor fifth under the seat
rdcox23
Vehicle: 2005 Wrangler LJ
Post by rdcox23 » Thu Apr 12, 2018 3:30 pm
Jeep Ride wrote:Good looking Jeep
Thanks!
I have always wanted an LJ. It's been a lot of fun building it up. Not anywhere close to being done yet.
LIVING IS:
Living is a thing you do
now or never.............which do you?
rdcox23
Post by rdcox23 » Fri Apr 13, 2018 8:53 am
Too funny not to share.
Sent from my iPhone using Tapatalk
LIVING IS:
Jeep Ride
Vehicle: 98 JeeP xj
Post by Jeep Ride » Fri Apr 13, 2018 11:29 am
That's a good one for sure
Key Board Crawler
rdcox23
Post by rdcox23 » Sat Apr 14, 2018 8:30 pm
I was busy again today....
LIVING IS:
rdcox23
LIVING IS:
Post by smccollamjr » Sat Apr 14, 2018 9:38 pm
Looks good!
wharthog69
Vehicle: 2008 JK
Post by wharthog69 » Wed Apr 18, 2018 9:46 pm
Nice!
rdcox23
Post by rdcox23 » Mon May 14, 2018 10:44 am
New heavy duty hinges and tire carrier, new replacement Bestop and a Teraflex mount for the Firestik.
Moved the spare tire down so it sits on the bumper now. Much better solution for vibrations and also keeps it low so I can see out the back window. It also takes the load off of the tailgate.
Working on a cowl cold air intake and a bolt in cage now.
LIVING IS:
Post by smccollamjr » Mon May 14, 2018 12:02 pm
Are those hinges pretty beefy? No matter how much WD I spray on mine they still squeak and that’s with no tire on it at all.
rdcox23
Post by rdcox23 » Mon May 14, 2018 10:35 pm
Hinges have a hidden grease fitting inside. I will get you a picture tomorrow. They are very beefy. Part of the Exogate system that I bought.
LIVING IS:
rdcox23
Post by rdcox23 » Mon May 14, 2018 10:40 pm
Got my Spectre Cowl Cold Air Induction installed tonight after two evenings of work. I can definitely feel the difference in throttle response, especially with the new muffler. And the driver's seat dyno says I have added some horsepower. But I'm not sure I would do it again, as it is a pain in the buttocks to install.
Only thing left now is the bolt in cage.
LIVING IS:
Post by smccollamjr » Tue May 15, 2018 7:52 am
What made it tough? When you said cork induction I thought you were pulling air from the area under the wipers.
rdcox23
Post by rdcox23 » Tue May 15, 2018 10:53 am
smccollamjr wrote:What made it tough? When you said cork induction I thought you were pulling air from the area under the wipers.
I am pulling air from the cowl. There is a second black pipe that is hard to see in the picture. It provides fresh air from the cowl to the filter. The pipe you can see easily in the picture provides air from the filter to the intake.
The first hurdle was drilling the intake tube and fitting it for the IAT sensor. The directions called for a 3/4" hole and it turns out you need close to a 15/16" to make it fit properly. But the real PITA is drilling a 3" hole to access the cowl. I tried three different hole saws and finally ending up drilling several smaller holes and connecting them with a sawzall. Reaching over the engine the entire time and trying to reroute all of the wiring was no small task either, but I finally got it done. I don't think I would do it again. Would be much easier to use the K&N and leave the cowl stuff alone.
LIVING IS:
Post by smccollamjr » Tue May 15, 2018 4:26 pm
Gotcha. I can’t see the other tube.
