The Build-2013 Rock Lobster Rubicon Unlimited
Pictures of meets...your Jeep...etc
BLUZTJ
Vehicle: 2004 Willys Editions
Re: The Build-2013 Rock Lobster Rubicon Unlimited
Post by BLUZTJ » Sun Sep 25, 2016 7:21 am
Nice looking ride there.
J ust
E mpyt
E very
P ocket
.........You Just Can't fix Dumb..........
2015 JKU Rubicon 2" spacer in front 1" in back
2004 TJ willys 5.5 lift with too much junk
1996 Camaro Z-28 convertible
Black2000TJ
Vehicle: 2000 Jeep Wrangler
Post by Black2000TJ » Sun Sep 25, 2016 8:49 am
Thanks, the last picture really captures how much of a difference the lift and tired made. It's looking like the next step will have to be some trimming in the rear as well as some different bumpers before it sees much off-road use. Surprisingly though, the 37s seem to clear the rock rail just fine in the rear.
Sent from my iPhone using Tapatalk
2000 Jeep TJ; locked Dana 44 rear, Dana 30 front w/air locker, Full Traction 6" long arm lift, 35"X12.5"X15" wrangler MTRs, Warn 9500HS winch, Atlas II transfer case.
Post by smccollamjr » Fri Oct 21, 2016 8:01 am
I saw this at Driveline yesterday. Looking great!
Black2000TJ
Post by Black2000TJ » Tue Oct 25, 2016 11:33 am
Picked the jeep up from Driveline on Friday. It now has a sleeved and gusseted front axle, chromo shafts front and rear, some HD diff covers, and 4.88s to get the power back up to a tolerable level. If you're looking for a place to do a re-gear on your jeep, or anything else driveline related for that matter, the guys at Driveline Service do excellent work.
Post by smccollamjr » Tue Oct 25, 2016 9:30 pm
I'll second that. They installed 4.88s and an e-locker 2 weeks ago. Craig's a great guy and does great work.
Black2000TJ
Post by Black2000TJ » Mon Apr 03, 2017 7:27 pm
It's been a while since my last update. So long, actually, that my build is pretty much finished up. Since the regear, the jeep has received front/rear Full Metal Fabworks steel bumpers with black powder coat, a 9,500 lb. smittybuilt xrc gen2 winch with synthetic line, a synergy tie Rod, a rough country dual steering stabilizer setup, an air compressor, an AEV heat reduction hood, a Tactik hinge tire carrier, Bushwacker flat fenders, a pretty cool custom front driveshaft from driveline service, and a soft top. I currently have a synergy front track bar relocation bracket that will be installed as soon as I pull the trigger on the synergy drag link & flip kit. If anyone is on the fence about which lift to buy, I can't say enough good things about Rock Krawler. I haven't heard a single squeak, rattle, or pop on road, off road, or otherwise.
Post by smccollamjr » Mon Apr 03, 2017 9:12 pm
Looks great! But you're never finished.
Jmoore938
Vehicle: 2006 LJ
Post by Jmoore938 » Mon Apr 03, 2017 10:21 pm
Good wheeling with you again this past Saturday out at East Lynn. Jeep performed great!
