Hi All.
I’m changing out the fuel injection on my 83 Scrambler and going with the Holley Off-road Truck Avenger. I’m undecided between the 670 or the 770 CFM. Does anyone have experience on which I should go with?
The motor is a 383 Stroker.
Here is a link to the Holley. https://www.holley.com/products/fuel_sy ... ts/0-90770
Thanks for the feedback.
Carburetor Size for Scrambler
- JKUR Kimo
- Lifted Poster
- Vehicle: 2014 JKU Rubicon
2014 JKU Rubicon
1983 CJ8 Scrambler
1983 CJ8 Scrambler
- TJinWV
- Lifetime Member
- Vehicle: 2006 TJ
Re: Carburetor Size for Scrambler
What's your use case? Are you going to be WOT mud running or rock bouncing? You'll definitely want the 770. If you're street/trail driving, the 670 would suffice and save a little at the gas pump.
Dan - TJinWV <><
2002 TJ, 2" OME lift, ARBs
.ɹǝʌo ǝɯ 11oɹ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
- highlandercj-7
- Curb Crawler
- Vehicle: 1976 CJ-7
I would can the carb idea and go with the FITech fuel injection. The only thing that holds my CJ back is the carb. I am going that route next. I have a 600 Edelbrock on a 6.0L AMX and it works fine for CFM. So the 670 would work if you had to go with a carb. But if you want the max potential out of the engine and Jeep go FI.
HIGHLANDERCJ-7
The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government. -Thomas Jefferson
